Date/Time: Sat, 04 May 2024 09:18:48 +0000
TPO Volume Profile Settings
View Count: 702
[2020-09-15 02:42:03] |
User148596 - Posts: 214 |
Hi, Is it possible to change the "Volume Graph Period Type" in a TPO chart from "Based on TPO Chart" to something else? I would like to use the "Draw Volume Profile" Tool and have one volume profile for a number of days on my TPO chart but I just keep getting volume profiles for each individual day on the chart. Thanks |
[2020-09-15 12:22:45] |
You cannot use Draw Volume Profile on a TPO chart. That will not work properly. You can add an independent volume profile on a TPO chart though with this Input: Volume By Price Study: Set as Independent Volume Profile for TPO Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-17 01:32:44] |
Worked like a charm, thanks!
