Date/Time: Thu, 02 May 2024 02:06:04 +0000
Getting an error message upon attempting to purchase an option
View Count: 481
[2020-09-14 19:11:25] |
User444954 - Posts: 4 |
Greetings, I am trying to buy an option, but the following message appears: SC Futures Order Routing/Data order update (Order reject). Info: TT order update (Rejected). Text: No limits | SenderSubID: AMPT108184. Internal Order ID: 1108. Service Order ID: 2898887. Symbol: MESU20 C3395.MES.FUT_OPT.CME. Account: AC108184 | 2020-09-14 17:23:22.855 * What do I have to do in order for the purchase to be successful? |
[2020-09-15 13:25:27] |
John - SC Support - Posts: 31293 |
You need to tell your broker about that message as they need to set the limits for you.
[2020-09-15 16:56:04] |
Hello, I reached out to AMP Futures regarding this issue. They have advised me that those options are not possible to be traded through AMP; verbatim: "Not through AMP, no options are available with the fix".
[2020-09-15 18:42:04] |
ok so AMP does not support options through TT FIX. You can have a look at using CQG instead: CQG Trading Platform Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-15 18:42:12
