Date/Time: Sun, 05 May 2024 09:27:32 +0000
Chart Trade Menu (swap panels) and moving an order
View Count: 1132
[2014-02-06 11:40:33] |
cross - Posts: 70 |
Chart Trade Menu appears on the left, under the mouse when a right click on a chart has been made.. and Chart Shortcut Menu goes on the right. That's fine. Unfortunately, if there is a Chart Tool under the right click, eg. a Rectangle which I use to mark ranges, then Chart Drawing Menu pops up and Chart Trading Menu goes on the RIGHT, away from the mouse. This cause me "what a heck" moments. Please, if possible, put Chart Trade Menu on the left, under the mouse in all occurances. For a somewhat same reason it would be good to have an option to enable a modifier key, eg. Alt in addition to the left mouse click to move orders on the chart. Sometimes I'd like to modify a Tool but pick the order. Thank you very much! PS: I've found that Ctrl-C/Ctrl-V don't work in the text input boxes (eg. Alert tab). Cut and paste is only possible from the right click context menu. Could the keys be also enabled? |
