Date/Time: Fri, 03 May 2024 14:01:31 +0000
Rollover problem
View Count: 485
[2020-09-14 16:36:53] |
John - SC Support - Posts: 31336 |
1. You would need to talk to TransAct about getting Package 5 instead of Package 3. Otherwise, you would need to have a direct account with us that you can use to connect to TransAct. Refer to the information here: Direct Sierra Chart Account 2. Most likely what you are seeing is just a difference in the symbol for the drawings. Refer to this setting: Chart Settings: Show Chart Drawings For Different Symbols (Chart >> Chart Settings >> Chart Drawings menu) And refer to this information regarding this section in relation to rollover and also note the section after this: Changing to a New Futures Contract Month: Allowing Lines and Other Chart Drawings From Other Contract Months to Appear on the Current Contract For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
