Date/Time: Tue, 30 Apr 2024 14:42:45 +0000
inputting custom chart period
View Count: 411
[2020-09-14 14:41:23] |
User223281 - Posts: 57 |
when inputting a custom chart period, for some reason the software doesn't register any number typed below 6.
[2020-09-14 16:30:29] |
John - SC Support - Posts: 31194 |
Are you referring to changing the chart period using the keyboard? If so, then we are not able to reproduce what you are stating, as it is working fine for us. Refer to the documentation here: Changing Chart Bars Period: Fast Changing by Keyboard For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-14 19:14:09] |
Maybe because you remapped those numbers to keyboard shortcuts.
