Date/Time: Sat, 03 Oct 2026 12:58:38 +0000
unable to get rid of error message when opening chartbook
View Count: 792
| [2020-09-13 17:55:07] |
| User525965 - Posts: 180 |
I've been trying to get rid of this error message for a while but can't figure out what's causing it. I closed the bonds chart, the redid it completely but error is still there. Can you please assist? pic attacched |
| [2020-09-13 20:55:37] |
What is the error message specifically? We do not see anything in usual in that log.
| [2020-09-14 00:33:32] |
that's the error, the log keeps coming up every time i open the chartbook
| [2020-09-14 10:42:53] |
Refer to: Message Log: Messages That Cause the Message Log to Automatically Open Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
