Date/Time: Wed, 25 Nov 2026 23:00:10 +0000
Candle stick Wick THICKNESS
View Count: 3983
[2020-09-13 17:27:06]
User375840 - Posts: 7
Sierra Charts:
It would be great if the THICKNESS of candlestick WICKS could be adjusted so they are THICKER or THINNER (the same way candle up/down Outlines can be adjusted).
This would make WICKS easier to spot - especially when the wicks are only 1-2 ticks in length
[2020-09-14 07:05:47]
User907968 - Posts: 887
You can change the wick thickness using these graphics settings:
Bar High-Low Down - Graphics Settings: Bar High-Low Down
Bar High-Low Up - Graphics Settings: Bar High-Low Up
[2026-02-13 17:57:39]
User_CY99 - Posts: 8
Hi, I was hoping for an answer for this, but I found that the Graphics Settings: Bar High-Low Down and Bar High-Low Up are not making the wicks thicker. And I am not using the Global Settings.
Anyone with ideas?
Thanks,
Carl
[2026-02-13 20:05:37]
The "Bar High-Low Down" and "Bar High-Low Up" graphics settings will change the width of the wick for a Candlestick Bar when you change the Width setting.
If this is not working, then the first thing to look at is whether you are using the correct Graphics Settings - Global or Chart, and be sure to change the appropriate one. Refer to the following:
Graphics Settings: Use Global Graphics Settings Instead of These Settings
If the above still does not resolve it, then what is the "Graph Draw Type" set to for your chart.
[2026-02-13 21:03:21]
Hi John:
Thanks, I had to use the Global Settings to change the wicks for the particular chart I needed to change.
Thanks,
Carl
