Date/Time: Mon, 29 Apr 2024 00:02:43 +0000
Chart Values for Tools - Begin and End Time
View Count: 771
[2020-09-13 09:16:06] |
nicktrader - Posts: 665 |
I noticed that my M3 chart shows begin and end time, but the M1 Chart only shows begin time (see pic). What is the reason for this? Many thanks |
Chart Values.png / V - Attached On 2020-09-13 09:15:06 UTC - Size: 4.13 KB - 211 views |
[2020-09-14 11:16:27] |
It is because the chart is not maintaining the array for the ending date-times. Add this study to the chart: Bar End Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-14 11:16:40
[2020-09-14 12:01:39] |
I'm afraid you didn't understand me properly (my fault). Only my M3 Chart shows the End Time, all other charts in the Chartbook do not show it. Even if I remove all studies in this M3, the End Time is shown. I am just wondering how this can happen. |
[2020-09-15 02:37:41] |
I think I have found the " bug". The left picture shows the "naked" M15 chart. Then I added the study "NB Calc...Values" and the right picture shows the End Time. If I remove the Study, the End Time is still displayed. |
Chart Values naked and NB Calc Values.png / V - Attached On 2020-09-15 02:37:03 UTC - Size: 30.55 KB - 217 views |
[2020-09-15 12:27:34] |
This is not a bug. If you want to remove the end time display, just reload the chart with Chart >> Reload and Recalculate.
