Date/Time: Sat, 04 May 2024 11:36:31 +0000
Equities Data Volume Profile
View Count: 658
[2020-09-12 01:13:38] |
BlueVein - Posts: 34 |
Hello, I just purchased your realtime equities data, and am trying to load volume profiles but they look very odd. What am I doing wrong? https://gyazo.com/712aa625cb862cba216cbfacd1621987 Any help is appreciated. |
[2020-09-12 22:37:21] |
Here is a better example. https://imgur.com/a/N6TBASa It seems to be an issue with the ticks per volume bar. But that setting is relative to the stock I am looking at. Does SC have a way to do rows or more standardized formats like other software? |
[2020-09-14 11:08:33] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image We need you to provide an image of the chart following the instructions above. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-14 15:59:01] |
http://www.sierrachart.com/image.php?Image=1600099126604.png
[2020-09-14 16:00:33] |
Maximum Bar Width is set to 80% and Automatic so trying to figure out why the profiles are so tiny and if it is normal to have those huge volume spikes on the All Bars in Chart VbP.
[2020-09-14 18:26:31] |
So take TSLA. If I have it as 1 tick/vol bar it looks supper messed up and jagged. Then I switch it to 25 and it looks normal. I am looking for a way to pull up many symbols and not have to change the tick value for them to be legible. It does not make sense at 1 tick a volbar will look tiny then at 25 that same area is large.
