Date/Time: Fri, 03 May 2024 00:19:13 +0000
Prevent Line Plot Between Sessions
View Count: 1074
[2014-02-05 19:52:04] |
User83762 - Posts: 61 |
How can I prevent a line (i.e. VWAP or Volume POC) from plotting between RTH sessions on an RTH chart, without changing from a line plot to a dash or other character? Thanks.
[2014-02-06 00:29:11] |
You really have to use a Draw Style which does not use a continuous line. There is no other possibility.
[2014-02-06 00:36:50] |
Thanks. This really needs to be added as a global setting of some sort; really helps keep charts clean.
