Date/Time: Sun, 05 May 2024 09:01:53 +0000
Quantity
View Count: 1061
[2014-02-05 19:35:50] |
User39772 - Posts: 311 |
When I trade via chart and change the quantity of shares, the step is sometimes 1 share and sometimes 100 shares. Where can I set it to 100 shares if I press the +/- buttons.
[2014-02-05 19:44:53] |
This is set through Global Settings >> Symbol Settings. Locate the symbol pattern for the Stock symbol you are trading and adjust the Default Order Quantity. That serves as the increment.
