Date/Time: Fri, 26 Apr 2024 18:37:56 +0000
Data file management file compression doesn't work with new versions
View Count: 1319
[2020-09-10 21:38:19] |
IconBob - Posts: 61 |
The data file compression option of Data Management doesn't work with current versions, I have to install version 2146 to get a version it works with.
[2020-09-11 03:54:46] |
This is not true. The functionality is working fine. There are detailed messages added to the Message Log indicating the progress like the following: Checking file to compress: C:\Work\SierraChartTesting\Data\ESZ19.scid | 2020-09-10 23:52:42.812
Not compressing file: No records found to compress | 2020-09-10 23:52:42.815 Checking file to compress: C:\Work\SierraChartTesting\Data\GBPCAD.scid | 2020-09-10 23:52:42.815 Combining old data records in GBPCAD.scid. | 2020-09-10 23:52:42.819 Reduced the size of GBPCAD.scid by 91%. | 2020-09-10 23:52:55.433 Checking file to compress: C:\Work\SierraChartTesting\Data\GBPJPY.scid | 2020-09-10 23:52:55.442 Combining old data records in GBPJPY.scid. | 2020-09-10 23:52:55.447 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-11 20:25:06] |
I'm talking about time compression from ticks to seconds on and data older than 90 days.
[2020-09-11 22:05:12] |
We do not see any problems with this.
[2020-09-11 22:15:21] |
I guess I need to send examples. Also are time compressions logged?
[2020-09-12 01:01:14] |
When you use the Intraday Data File Management function, you will get log messages like you see above for the files being checked and/or compressed.
[2020-09-20 17:27:35] |
After reading below I unsaved .scid files created before 2164 and redownloaded them and the data management time compression worked. - A problem with the building of historical data records in some cases of 1 second and higher from Sierra Chart historical data servers has been found and corrected. 1 Tick data has not been affected. It is not completely known all of the issues that would have been caused by this. One issue was that there would be a long-duration record returned covering a larger amount of time than the requested record size. This would cause a long-duration chart bar in the chart. This issue has existed since the release of millisecond time stamping in the last two weeks. If there are any historical data issues in your charts, then refer the help topic 2.1.2 for instructions to re-download the data. . If you are using sub instances of Sierra Chart, then update to version 2164 or higher because this problem may affect the data provided to sub instances if it is requesting data in 1 second time units or higher. Date Time Of Last Edit: 2020-09-21 03:44:56
