Date/Time: Mon, 06 May 2024 00:25:36 +0000
Crosshairs
View Count: 1109
[2014-02-05 19:01:17] |
ZH Support - Posts: 19 |
Sierra, I am on the new version of the charts and have everything set up correctly. My issue is when I select the Crosshair the do not show. The courser doesnt change off the pointer. I have downloaded version 1081 but still have the same issue. All the colors are correct and the setting are correct too. Please let me know what I can do. Jake |
[2014-02-06 00:51:59] |
Jake, Make sure the Global Settings >> Tool Settings >> Chart Values >> Always Active When Selected option is disabled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
