Date/Time: Wed, 08 May 2024 13:00:15 +0000
Selecting (and moving) several horizontal lines (or other drawing objects) simultaneously?
View Count: 388
[2020-09-10 13:32:10] |
Yoshi-san - Posts: 11 |
Hi, I would like to select and move several horizontal lines (e.g. by selecting the objects with Shift + Left Mouse Click). Is there a possible to achieve that task or would you probably consider to implement such kind of feature?
[2020-09-11 09:49:49] |
There is not a way to do this. But maybe you can create a custom study which does this: Using Drawing Tools From an Advanced Custom Study And refer to: Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
