Date/Time: Tue, 07 May 2024 06:37:02 +0000
Incorrect Delta difference numbers in Display Volume in Bars (Volume by Price study)
View Count: 409
[2020-09-10 13:20:20] |
Alv P - Posts: 37 |
There is simply no option to see the delta difference number in each column ( volume profile visualization ) [Diagonal Ask Vol Bid Vol Difference] and [Diagonal Ask Volume - Bid Volume] they are not the correct visualization from the resulting delta number when you configure [Diagonal Ask Volume - Bid Volume (in:48)] and [Diagonal Difference of Bid And Ask Volume Coloring (in:49)] |
[2020-09-11 06:12:46] |
We are not understanding what you are saying.
[2020-09-11 07:20:55] |
Alv P - Posts: 37 |
Thank you for your response; Yes, there is no option in Display Volume in Bars (in:46) to have this visualization of the right difference from Delta: Date Time Of Last Edit: 2020-09-11 07:21:32
AddText_09-11-09.03.45.jpg / V - Attached On 2020-09-11 07:19:02 UTC - Size: 32.43 KB - 173 views |
