Date/Time: Tue, 07 May 2024 19:57:18 +0000
Version 2162/2163 Known Issue with Wine/Linux
View Count: 723
[2020-09-10 00:28:17] |
Due to the use of overlapped receive I/O for network communication, with version 2162 and 2163, these versions should not be used with Wine/Linux. We have become aware of a known issue involving this method of network I/O with that operating system. We still have to develop a solution to this. So avoid using these versions if you are using Wine/Linux. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-14 23:09:03] |
ertrader - Posts: 645 |
Has this been resolved for the latest release 2168 ?
[2020-09-15 01:53:21] |
Yes there should not be a problem. It would be impossible that there would be a continued issue.
