Date/Time: Thu, 02 May 2024 20:11:47 +0000
[User Discussion] - current traded bid/ask reset
View Count: 717
[2020-09-07 20:06:59] |
AndyB - Posts: 96 |
hi, i would like the option to have the current traded bid/ask volume on the DOM to automatically reset at a specified time frame interval. how can I do this automatically without manually doing it?
[2020-09-10 19:48:06] |
User308633 - Posts: 17 |
I've asked this question but it's still unanswered. Any solution? |
[2020-09-10 22:58:59] |
This is not supported.
[2020-09-10 23:04:13] |
AndyB - Posts: 96 |
is it possible to make something like the recent bid ask timeout in ms for current traded bid/ask and bid/ask stacking and pulling? i often forget or cant make it to my desk at the start of the day and would like to see those things or adjust it. side question i was wondering if it were possible clear any of the above (manually) and not have it clear for the same symbol on another DOM. I have two doms with the same symbol , one on my footprint chart (trade chart DOM) and another independent. id like to be able to clear the recent bid/ask or whatever it may be, but still see it in a seperate one as its been accumulating with no clearing. would the only way to accomplish this be to run the second on a seperate instance? Thanks for your response |
