Date/Time: Fri, 03 May 2024 17:38:48 +0000
How to Daily OHLC to Prior Evening Session
View Count: 813
[2020-09-07 17:59:37] |
User450463 - Posts: 118 |
I have a TPO chart, and have selected "Exclude Evening Session Profile Except for Last". In other words, there is one evening session on the chart and many RTH sessions. It's Monday morning, and I want an OHLC study to apply to SUNDAY EVENING. I choose the 'Daily OHLC' study. When I set "Reference Days Back" to 0, it applies the study to the current day RTH (Monday morning). When I set "Reference Days Back" to 1, it applies the study to the Friday RTH session. How do I get a High and Low to show up for the Sunday evening session on Monday morning? Or the Monday evening sesssion on Tuesday morning, and so on and so forth. Daily OHLC settings attached. Thanks. |
Daily OHLC.JPG / V - Attached On 2020-09-07 17:59:18 UTC - Size: 103.47 KB - 213 views |
[2020-09-07 22:17:29] |
To do what you want, you would need to use the High/Low for Time Period - Extended study. This will allow you to set the times for the evening session to create the extended lines into the day session. If you want to have all 4 lines (Open, High, Low, and Close/Last) then you would need to use 2 copies of the study and change the appropriate Inputs and colors for the lines. Refer to the documentation for the study here: High/Low for Time Period - Extended Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
