Date/Time: Mon, 06 May 2024 16:45:30 +0000
Rithmic question
View Count: 699
[2020-09-06 18:11:07] |
gr93 - Posts: 18 |
SC has made it clear that they will not be supporting Rithmic data feeds, but will order routing through Rithmic still be supported? If we wanted to trade through TopStep or OneUp, would it be possible to use the SC Data Feed and route orders through Rithmic (after the official support is discontinued)? Will this be supported by SC?
Date Time Of Last Edit: 2020-09-07 21:13:15
[2020-09-07 22:06:01] |
There may be a change with this. And we are discussing this with Rithmic. We hope to have more information towards the end of the week.
[2020-09-07 22:20:45] |
gr93 - Posts: 18 |
Thanks for the update. For now is there no plan to continue support for Rithmic execution whilst using the SC Data Feed? Mainly confused whether the Rithmic support dropping is for the feed itself or even for execution while using a SC Data Feed such as Denali. Would be useful to know the current plan as there is no definite answer yet from your discussions with Rithmic.
Date Time Of Last Edit: 2020-09-07 22:24:11
[2020-09-08 19:28:48] |
For now is there no plan to continue support for Rithmic execution whilst using the SC Data Feed? This is supported but refer to the information on this page:Is Historical and Real-time Futures Data Included?: Is Historical and Real-time Futures Data Included? A live funded account is required. Not one of these trading evaluator/funding company accounts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-08 20:22:47] |
gr93 - Posts: 18 |
I read that page but am still a bit confused on how it's applicable here. The question I have is not whether it's possible to get data from the prop firms, but whether it's possible to use the SC data and execute through the orders through the Rithmic connection provided by the prop firm. If they provide the Rithmic login credentials, will SC continue to support a method simply executing orders through it? I'm not concerned with problems of Rithmic data (ex. laggy or missing data) because I will be using the SC Data Feed. I just want to know if SC will be dropping support for Rithmic entirely, or only for using the data feed itself.
[2020-09-08 22:35:14] |
gr93 - Posts: 18 |
I read it again and think I understand it better now. Lets say I have a funded live AMP account and use that to fulfill the requirement in order to use the SC Data Feed. Would I then be able to use the SC Data Feed on my charts, and have my orders executed through the Rithmic login credentials provided by these prop firms? Is this something that will be supported by SC?
[2020-09-10 06:27:04] |
Would I then be able to use the SC Data Feed on my charts, and have my orders executed through the Rithmic login credentials provided by these prop firms Yes this is true. I just want to know if SC will be dropping support for Rithmic entirely, This has been the plan effective January 2021 in newer versions released of Sierra Chart but we likely will delay this and we are in discussion with Rithmic over an alternative interface. So at this point there are no clear plans to end support.I read it again and think I understand it better now. Lets say I have a funded live AMP account and use that to fulfill the requirement in order to use the SC Data Feed. Would I then be able to use the SC Data Feed on my charts, and have my orders executed through the Rithmic login credentials provided by these prop firms? Is this something that will be supported by SC?
So yes this is still currently the case.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-10 06:27:26
