Date/Time: Sat, 04 May 2024 06:01:29 +0000
Adding a custom indicator HELP!
View Count: 1038
[2020-09-06 15:47:43] |
User397898 - Posts: 2 |
Hello, I have a custom indicator I would like to add, its already in DDL format. I saved to my sierra charts data folder. I already reviewed the pages on how to add the custom indicator but they don't seem to help. |
Relative Volume saved in data folder.PNG / V - Attached On 2020-09-06 15:44:49 UTC - Size: 99.79 KB - 294 views Attachment Deleted. Capture.PNG / V - Attached On 2020-09-06 15:45:52 UTC - Size: 135.35 KB - 250 views |
[2020-09-06 16:15:17] |
Ackin - Posts: 1865 |
It will not work for you with respect to your image where the library change date can be seen. All custom libraries must be recompiled for version 2151 and higher. You have version 2158 but the indicator in the library is 2 years old. You need to recompile the library from source code. If you do not have it, contact your developer.
[2020-09-07 22:03:44] |
You probably need to recompile the custom studies for the current versions. Refer to: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2156 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-07 22:04:02
[2020-09-07 22:54:53] |
Thank you I will recompile and and get back to you to see if we are okay to go.
