Date/Time: Wed, 08 May 2024 11:26:40 +0000
Request: Forex Currency Index Data for Morningstar FX Feed
View Count: 791
[2020-09-04 17:02:09] |
ticinotrader - Posts: 378 |
Dear Support, Since the great, realtime Morningstar FX feed is available, would it be possible to add/create a new set of Currency index symbols that use data of Morningstar? There are 22 currencies available (listed under the available Symbols) with the Morningstar FX feed so this would create 22 FX Currency index symbols in total that could be used solely with Morningstar (instead of the 7 symbols of FXCM). The currencies are: AUD, BRL, CAD, CHF, CNH, CZK, DKK, EUR, GBP, HKD, HUF, JPY, MXN, NOK, NZD, PLN, RUB, SEK, SGD, TRY, USD, ZAR Can you please consider creating/adding these new symbols to your Morningstar offering? Thank you in advance. |
[2020-09-08 00:30:57] |
We will have to see about this later.
