Date/Time: Mon, 29 Apr 2024 17:26:03 +0000
Total monthly cost
View Count: 1378
[2014-02-05 04:20:43] |
User68413 - Posts: 1 |
I have OEC/ Gain Capial as my platform and they only give 5 to 7 days of tick data and only allow I think it is 5 charts open. If you could direct me on how to get the maximum historical tick data and a minimum of 10 open charts and the cost for this based on package 5 I would appreciate it. I chart the 6A 6C 6E ES NQ YM ZB ZN DX. Is there a better combination than OEC/Sierra Charts? Thanks, Darin Graham Date Time Of Last Edit: 2014-02-05 05:37:29
[2014-02-05 17:57:04] |
When you use Sierra Chart with OEC, you will have access to several years of historical tick by tick data for all of the symbols that you list. There still is a restriction to receive tick by tick data on 5 symbols at a time. To overcome this restriction you can use the Sierra Chart Real-time and Historical Futures Data Feed: http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart does support other trading services and they are all listed here: http://www.sierrachart.com/index.php?l=doc/data.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
