Date/Time: Mon, 06 May 2024 12:14:26 +0000
FX IB commission in Trade Activity Log
View Count: 1161
[2014-02-04 10:04:52] |
User57821 - Posts: 18 |
Is there a way to automatically receive information on the exact commission from Interactive Brokers to Trade Activity Log or only manually set in the Symbol Settings? I do not know how to properly set up the Commission for FX pairs, where the Minimum per Order is $2 and is therefore a problem for orders less than 100K. Thank you. Martin |
[2014-02-05 03:57:22] |
You can only manually set a simple commission through the Global Symbol Settings.
