Date/Time: Tue, 07 May 2024 19:14:48 +0000
YM problem with Crossland/TT
View Count: 2314
[2013-04-17 13:57:13] |
TI Anon - Posts: 36 |
For last few days, YM intraday chart does not load properly. Checked with Crossland and they say there is no problem on their end. They said to use the CBOT Gateway.(FWIW: Yesterday I did not have the problem today it is there, the day before yesterday I had to use Iqfeed for backfill) Loading YM from Iqfeed and then using Alterante Real-Time Update Symbol from TT gets me a round the problem but should be able to load backfill from TT. When loading from Iqfeed using the same chart settings as the TT chart that doesn't load. V965 loaded on 4/15 but problem was in previous, also. |
[2013-04-17 14:33:01] |
This is now resolved.
[2013-04-17 15:01:22] |
Just opened a new intraday chart using TT symbol, still no backfill. 1 day loading-1 min bars v965,closed and resarted SC.
[2013-04-17 15:08:29] |
Here is a 2day chart clearly showing missing data from today.
Date Time Of Last Edit: 2013-04-17 15:08:44
417.bmp - Attached On 2013-04-17 15:07:36 UTC - Size: 1.79 MB - 592 views |
[2013-04-17 15:08:32] |
What symbol? For the time being go to the chart and select Edit >>Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-17 15:26:10
[2013-04-17 15:15:54] |
Edit >>Refresh All Data for Symbol does not exist-Delete All Data and Download does.
[2013-04-17 15:26:27] |
We gave the old command name. It has been corrected.
[2013-05-17 16:05:34] |
Futures Operator - Posts: 239 |
TI Anon, were you able to resolve this? Does the Crossland/TT feed include intraday backfill?
[2013-05-17 17:24:28] |
Yes, SC resolved the problem. Intraday backfill has been available on TT, there are limitations and deficiencies that have been documented in other threads. Be sure to check the Old Support board for more discussions.
[2013-05-19 05:05:18] |
Thanks for your reply, would you please contact me at futuresoperator1@gmail.com ?
[2013-06-25 13:01:40] |
This is occurring again.....V991(happened on v990 also) For last few days, YM intraday chart does not load properly. Checked with Crossland and they say there is no problem on their end. They said to use the CBOT Gateway.(FWIW: Yesterday I did not have the problem today it is there, the day before yesterday I had to use Iqfeed for backfill) Loading YM from Iqfeed and then using Alterante Real-Time Update Symbol from TT gets me a round the problem but should be able to load backfill from TT. When loading from Iqfeed using the same chart settings as the TT chart that doesn't load. |
[2013-06-25 16:30:38] |
Problem is now resolved.
[2013-06-25 18:30:28] |
TI Anon, or anyone, what is the difference between a CME or CBOT gateway for a symbol when both are available, how do you choose which one should be used?
[2013-06-25 22:12:44] |
This depends upon the particular FIX adapter that the broker is using.
