Date/Time: Tue, 10 Nov 2026 05:52:46 +0000
How to set Decimal places is 0.
View Count: 1075
[2020-08-30 11:27:00]
User509345 - Posts: 44
like volume is 1285.0000 -> 1285.Thanks.
imageSnipaste_2020-08-30_19-23-17.png / V - Attached On 2020-08-30 11:26:15 UTC - Size: 89.47 KB - 414 views
[2020-08-30 11:47:16]
Ackin - Posts: 1865
try:
Chart Studies: Settings and Inputs Tab >> Value Format
[2020-08-30 12:32:25]
Thanks. I get it. Do you konw why I dupliate the chart , change the symbol, original chart simbol was changed.
[2020-08-30 20:23:33]
John - SC Support - Posts: 48480
Most likely the chart had linking for the symbol setup. Refer to the following:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber
