Date/Time: Sun, 13 Jul 2025 07:05:00 +0000
[Programming Help] - ACS exchanged files after updating to new version
View Count: 751
[2020-08-27 16:26:10]
User783475 - Posts: 12
Hi, I did an Advanced custom study, but today I updated SC to the new version and now, when I try to build my DLL, a lot of errors occur.
Mainly the cause is some variable type changed
e.g. sc.ChartbookName has changed from SCString ChartbookName to SCString (SCDLL* ChartbookName)()
So now, when in my code appears
if (sc.ChartbookName == OrderDetails.SourceChartbookFileName)
it occurs the error
no match for 'operator==' (operand types are 'SCString (*)()' and 'SCString')
Can anyone help me?
[2020-08-27 17:17:52]
User907968 - Posts: 842
You can read about the change in this post from Sierra Chart Engineering - Version 2151 Available: Foundation For Millisecond/Microsecond Timestamping | Post: 230981
You could also inspect the header file - sierrachart.h - in your ACS directory and see the changes.
sc.ChartbookName
is now
sc.ChartbookName()
[2020-08-27 18:40:45]
Really THANKS! It's exactly what I needed
