Date/Time: Sun, 28 Apr 2024 22:09:03 +0000
Volume By Price study issue.
View Count: 1876
[2013-04-17 13:07:24] |
mittalpa - Posts: 28 |
Hi In the attached chart, the VbP study is not working properly. There are lot of spaces in between its bars. Not sure why it is happening. I have attached the study collection for review. Please advise what can be done to display it correctly. Thanks AJ |
VbP_Issue.png / V - Attached On 2013-04-17 13:06:20 UTC - Size: 50.12 KB - 660 views VolumeByPrice-.StdyCollct - Attached On 2013-04-17 13:06:38 UTC - Size: 7.67 KB - 630 views |
[2013-04-17 13:14:44] |
Make sure the Volume at Price Multiplier in Chart >> Chart Settings is set to 1.
[2013-04-17 13:24:57] |
It worked... Not sure how that changed. Maybe that value somehow should be reflected in VbP study properties. Thanks
