Date/Time: Thu, 02 May 2024 07:27:43 +0000
topstep using sierra chart
View Count: 25801
[2021-07-20 15:32:55] |
binaryduke - Posts: 360 |
Thank you. My error on Step 7. It appears the various evaluator-specific servers (TopStep, MES, uProfit) are not provided. This is presumably a Rithmic matter? |
[2021-07-20 15:37:03] |
Yes.
[2021-07-20 22:00:03] |
Ticks - Posts: 174 |
Yes. When will this be corrected as this Direct-DTC interface is worthless to SC customers who want to use SC and a Funding company?
[2021-07-20 22:13:58] |
Technical - Posts: 148 |
Ticks: When will this be corrected as this Direct-DTC interface is worthless to SC customers who want to use SC and a Funding company?
Before you go down this road too far, ask your funding company if DTC is working for them. If so, ask them for a generic config/chartbook to test. Please let us know how that works out. |
[2021-07-21 00:30:32] |
Well, I guess I wont have to worry if Direct-DTC interface will connect to UProfit. The Direct-DTC interface isn't enabled on my SC package 3.Even tho all the other trading services are. |
not enabled.PNG / V - Attached On 2021-07-21 00:30:22 UTC - Size: 177.31 KB - 349 views |
[2021-07-21 00:34:24] |
SC support.Why isnt Direct-DTC interface enabled on SC package3 when all the other services are?
[2021-08-02 18:04:19] |
User588405 - Posts: 2 |
SC support.Why isnt Direct-DTC interface enabled on SC package3 when all the other services are? Has this been answered? |
[2021-08-02 18:17:41] |
John - SC Support - Posts: 31293 |
In order to use the new Rithmic Direct - DTC connection you need to be on Package 5 or higher.
[2021-12-20 18:15:50] |
fxzen - Posts: 14 |
Just wanted to update all that TopStep is now supporting Sierra Chart via the Rithmic - DTC connection and has updated their connection instructions to reflect the changes.
[2021-12-23 16:32:28] |
Here are the Sierra Chart instructions for Rithmic: Rithmic Trading Platform Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
