Date/Time: Sat, 04 May 2024 04:44:50 +0000
CCI average
View Count: 1454
[2014-02-03 21:17:20] |
narcese - Posts: 58 |
Any chance the aforementioned indicator can be used with S Charts? The CCI Average study plots an average of the Commodity Channel Index over a defined time period. thoughts? |
[2014-02-03 22:03:17] |
You can do this by using the Based On feature with a Moving Average-Simple study to base it on the Commodity Channel Index. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#BasedOn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-04 12:12:39] |
Can someone walk me through this procedure? Want to make sure I do it correctly. Thanks, |
[2014-02-06 02:56:21] |
Yes. We apologize for the delay. We have prepared a study collection for you here: CCI Average | Post: 24235 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
