Date/Time: Sun, 19 May 2024 06:52:40 +0000
Order Types
View Count: 427
[2020-08-25 20:24:22] |
User996274 - Posts: 80 |
what order type would be used if u wanted to go long after a support level had been broken But only if the price breaks back up for instance: say I wanted to go L 52 but only after it has reversed up from a downward move Is that the "Stop Trigger" command? If so the stop = the price i want to go L The trigger would be say 2 points under = 50 The trade would not trigger unless we hit 50 then reversed up to 52? The target and Stop loss would still be dictated by the "target/stop" in trade window? |
[2020-08-26 00:36:57] |
Refer to this page: Order Types Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
