Date/Time: Sun, 19 May 2024 07:52:03 +0000
volume colored bars
View Count: 875
[2020-08-25 18:41:17] |
User425645 - Posts: 113 |
hello, is their a study that can color candlestick bars based on volume? thanks
[2020-08-25 19:32:51] |
Ackin - Posts: 1865 |
Sierra chart default study: Volume - Colored Based on Volume Volume - Colored Based on Volume - with settings Drawstyle ColorBar and use Region 1 (main chart) if you want Ask/Bid coloring: Volume Study and color shading |
[2020-08-26 00:25:24] |
You would need to use the Color Bar Based on Alert Condition study (probably multiple copies of this study) and setup your conditions for each copy for how to color the bars. Refer to the following: Color Bar Based on Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
