Date/Time: Sun, 19 May 2024 04:36:41 +0000
[Programming Help] - Version 2158. question on calculating values.
View Count: 441
[2020-08-24 09:00:25] |
2garin - Posts: 184 |
Good day support. In the latest version of the terminal, I noticed inaccuracies in the calculation of indicator values. The table shows the condition for the alert (14). the alert was triggered On (11). The alert did not work on (12). the indicator values are the same in both cases (11, 12). I didn't see this in previous versions. Date Time Of Last Edit: 2020-08-24 22:03:13
[2020-08-25 05:28:03] |
fractional values are not calculated correctly
[2020-08-25 11:48:02] |
Sawtooth - Posts: 4000 |
In the RWI study, set the Value Format to 0.00000001 This will allow you to see where they may not actually be equal. |
[2020-08-25 21:50:04] |
Thanks for the help. Differences are visible after the third sign.The question is removed. |
