Date/Time: Sat, 18 May 2024 22:45:21 +0000
Market Depth DOM on Delayed Future E6U20
View Count: 456
[2020-08-23 19:24:05] |
User39772 - Posts: 311 |
Hello, Trading Chart DOM is on. Is it possible to adjust the Market Depth on the Bid/Ask side according to my personal preferance ? I found Chart DOM Settings -> Max Bid/Ask Depth, but it seems an entry has no impact. |
[2020-08-25 01:26:01] |
What exactly do you want to do?
[2020-08-25 10:50:00] |
After opening a Trading DOM I want to set the number of price levels shown in the Bid/Ask columns to my preferred value.
[2020-08-25 16:53:06] |
Refer to this setting: Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
