Date/Time: Wed, 08 May 2024 10:52:27 +0000
[User Discussion] - Delta divergence study code
View Count: 2102
[2020-08-20 19:01:00] |
simonklaff - Posts: 3 |
Hello, I found that the delta divergence custom study is pretty accurate and wanted to see if the code is public. I found this thread but the link in it doesn't work. Delta divergence Thank you |
[2020-08-20 19:08:02] |
Ackin - Posts: 1865 |
try: https://www.sierrachart.com/AdditionalFiles/UserContributedACS_SourceCode/DeltaDivergence_v3.cpp |
[2020-10-16 13:10:24] |
User61576 - Posts: 418 |
are you refering to this?
Screenshot_2.png / V - Attached On 2020-10-16 13:10:10 UTC - Size: 50.02 KB - 661 views |
[2020-10-16 13:31:26] |
yes
[2020-10-16 13:47:29] |
is there any recommened setup to use this for intraday usage?
[2020-10-17 17:16:03] |
if i remember this correct, there was additional condition for entry: mark an entry only if price is breaking above / below (long/short) the bar where the divergence happened does anyone know how i can add this to the study? |
[2020-10-17 18:15:21] |
From cpp source: jdt Delta Divergence Author: jsyd Date: 11/13/2011 Try to find him here on the forum. I think it could be solved simply but also with the help of the Sierra study Color bar based on alert condition btw It is not a problem to complete the change you require, if you do not need the source code for it I can include it (modified version or create a reference study that communicates with that study with a set of conditions that you will need) among other studies in the free library. If you want to register: https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free Date Time Of Last Edit: 2020-10-17 18:22:48
[2020-10-17 18:31:24] |
i will be happy to learn the code change as well, will be happy if you could share
[2020-10-17 18:42:23] |
I understand that, in which case wait for someone else. (bradh,User907968,Kiwi....)
