Date/Time: Tue, 30 Apr 2024 00:15:25 +0000
Mirus Futures Question
View Count: 3220
[2013-04-17 10:50:24] |
User55519 - Posts: 37 |
Hello, forgive me as I know this was already partially addressed in a very old post from two years ago: http://www.sierrachart.com/supportboard/showthread.php?t=30155 But I do not completely understand the response. Can Mirus Futures be interfaced into Sierra charts as a brokerage and for trade execution? (I will use another service for data feed) Thanks! |
[2013-04-17 13:09:41] |
Yes, you can use Mirus Futures for market data and trading with Sierra Chart. Follow the instructions here: http://www.sierrachart.com/index.php?l=doc/ZenFire.php The thread/subtopic you linked to is now out of date and has been deleted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-17 13:10:08
[2013-04-17 13:40:44] |
Thanks for the quick response, and the link. It is difficult to tell from those instructions though - Is it possible to use a data service other than Zen Fire, and use Mirus Futures at the trading/brokerage service?
[2013-04-17 13:53:16] |
Yes. Please refer to this page here: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-17 15:38:16] |
Great thanks! Also want to say Sierra Chart is awesome.
