Date/Time: Mon, 20 May 2024 17:23:16 +0000
[User Discussion] - help with plotting horizontal line
View Count: 619
[2020-08-18 01:32:02] |
User681150 - Posts: 62 |
i cant plot a 0.0 horizontal line using ACSIL. if i change it to 1.5 using SetFloat(1.5) it works, if i change to SetFloat(0.0) nothing same with SetInt. whats the best way to plot a ZERO line in my subgraph. I want to set a line between positive/negative values. thanks thanks SCSubgraphRef sgZeroline = sc.Subgraph[1]; int zeroline = 0; if(sc.setDefaults) { sc.Subgraph[1].Name = "zeroline"; return }; sgZeroline[sc.Index] = zeroline; Date Time Of Last Edit: 2020-08-18 02:26:53
[2020-08-18 02:32:37] |
if i use zeroline.SetFloat(0.0001)
sgZeroline[sc.Index] = zeroline.GetFloat(); it works and sets a horizontal line "close enough" but setting it to 0.0000 does not work. go figure. |
[2020-08-18 03:06:39] |
User90125 - Posts: 715 |
In the sc.SetDefaults section try adding sc.DrawZeros = 1; |
[2020-08-18 06:00:44] |
User907968 - Posts: 804 |
ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].DrawZeros
