Date/Time: Mon, 02 Nov 2026 03:27:10 +0000
Data file setting
View Count: 868
[2020-08-17 19:47:26]
User425645 - Posts: 123
Hello, i am unable to change my "data range in file" to a closer date to cut down on storage on my disk. everytime i try to change it it flashes and goes back to original date. thanks
imagesc.PNG / V - Attached On 2020-08-17 19:47:22 UTC - Size: 134.79 KB - 378 views
[2020-08-18 12:39:58]
There really is not an automatic way to do what you want to do.
If this is a symbol that you access, then we recommend you leave it as it is.
Rather, refer to the information here to find symbols you no longer need and how to remove the files to reduce space:
Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency
Or compress older data:
https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#IntradayDataFileManagement
Date Time Of Last Edit: 2020-08-18 12:40:23
