Date/Time: Sun, 19 May 2024 04:56:33 +0000
Time Frame Problem
View Count: 532
[2020-08-17 16:37:04] |
User160486 - Posts: 36 |
The time frame on the bottom of some of my charts are not posting instead they show 0-00H and 0:00 across the bottom of the charts. For example, on the EUR/USD it shows 0:00H no matter what time frame vs The GBP/JPY for example that shows time frame. See attached image.
Screenshot (4).png / V - Attached On 2020-08-17 16:35:53 UTC - Size: 730.77 KB - 201 views |
[2020-08-17 19:12:24] |
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
