Date/Time: Mon, 20 May 2024 14:01:39 +0000
consulta
View Count: 563
[2020-08-17 16:26:39] |
User228318 - Posts: 7 |
Hola, quisiera saber si existe la posibilidad de que al hacer clic en la orden limit, la orden quede flotando sin mantener el botón del mouse presionado y cuando quiera posicionar la orden tenga que hacer clic nuevamente. Eso existe en Ninja Trader. Es decir... abro una orden limite, hago un clic, y queda selechinada y al hacer clic nuevamente se suelta. Se entiende? Saludos |
[2020-08-17 19:27:03] |
From Google Translate: Hello, I would like to know if there is a possibility that when you click on the limit order, the order will be floating without keeping the mouse button pressed and when you want to position the order you will have to click again. That exists in Ninja Trader. That is ... I open a limit order, I click, and it is selected and when I click again it releases. It is understood? Refer to this setting here: Global Trade Settings Windows: Use Click, Release, Click Method to Adjust Orders (Global Settings >> Chart Trade Settings >> General >> Order Entry) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-17 20:00:19] |
muchas gracias, fue de mucha utilidad! Ahora quisiera saber si es posible que al seleccionar la orden y moverla se puede mostrar la orden en la ubicación actual ya que cuando la selecciono desaparese y solo se ve la orden seleccionada. Gracias!
[2020-08-18 12:23:45] |
Translation: Thank you very much, it was very useful! Now I would like to know if it is possible that when selecting the order and moving it, the order can be shown in the current location since when I select it, it disappears and only the selected order is seen. Thank you!
No this is not supported.
