Date/Time: Mon, 02 Nov 2026 03:25:53 +0000
Crosshairs to Hand tool
View Count: 1510
| [2020-08-17 13:02:42] |
| User210127 - Posts: 23 |
Hello Support, a quick one: How to have the crosshairs with value on right scale by default, which switches to hand tool when left clicking (without chart values window)? Thanks a lot |
| [2020-08-17 18:57:03] |
Refer to the Action when Other Tools Selected setting for the Chart Values tool: Chart Drawing Tools: Chart Values Tool Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
