Date/Time: Sun, 19 May 2024 01:42:04 +0000
Custom Study does not work anymore on newest Sierra Chart Release (16/08/2020)
View Count: 739
[2020-08-16 20:51:43] |
Frostation - Posts: 11 |
It seems that the newest Sierra Release no longer supports custom study "UserContributedStudies_64.scsf_ECIVwap". After updating the study simply does not load within the Chartbook. I then had to revert to a previous known version. I can confirm that the study works correctly on version 2118. Can it be advised if this may be an issue that will be fixed on the next release? |
[2020-08-17 10:39:44] |
Update to the latest prerelease: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
