Date/Time: Sun, 05 May 2024 09:46:31 +0000
Arnaud Legoux Moving Average
View Count: 3628
[2020-09-20 05:21:24] |
Yes update Sierra Chart to the current version to find the study.
[2020-09-20 13:18:19] |
User223734 - Posts: 101 |
Dear all, I noted that the Offset for Sierra Chart Alma is "0.5" whereas other is "0.85", any different? |
[2020-09-21 05:51:05] |
SC Support Tom - Posts: 450 |
WRT Post #26: I noted that the Offset for Sierra Chart Alma is "0.5" whereas other is "0.85", any different? 0.5 is just the default value of the Offset. You are free to change it to 0.85 in the Study Settings Window: Chart Studies: Study Settings Window |
[2020-09-21 05:51:31] |
Documentation for this study is now available here: Moving Average - Arnaud Legoux |
[2021-03-06 02:59:57] |
User504778 - Posts: 22 |
SC Support, Is it possible to add an Intermediate Study Calculation Function for ALMA so we can easily use it in ASCIL custom study programs? Thanks. |
[2021-03-11 07:46:49] |
WRT Post #29: Is it possible to add an Intermediate Study Calculation Function for ALMA so we can easily use it in ASCIL custom study programs? Yes it is possible. I will be discussing this with John tomorrow. Date Time Of Last Edit: 2021-03-11 07:48:46
[2021-03-28 00:21:56] |
Where I can access the details of Intermediate Study Calculation Function?
[2021-05-20 06:06:10] |
WRT Post #29: Is it possible to add an Intermediate Study Calculation Function for ALMA so we can easily use it in ASCIL custom study programs? This is done. Apologies for the delay. I required some training on the development server before I was able to implement this function. You can find the documentation for the Intermediate Study Function sc.ArnaudLegouxMovingAverage() here: sc.ArnaudLegouxMovingAverage() Also, I rewrote the study function Moving Average - Arnaud Legoux so that it calls the above function. The Number of Bars To Calculate Input has been removed. These changes will show up in the next release of Sierra Chart. Date Time Of Last Edit: 2021-05-20 06:20:01
[2021-06-02 00:46:16] |
May I know what is ASCIL custom study programs?
[2021-06-02 14:10:23] |
John - SC Support - Posts: 31362 |
It is a custom study that is coded using the ACSIL interface to Sierra Chart. Refer to the information starting here: Advanced Custom Study Interface and Language (ACSIL): Introduction For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
