Date/Time: Thu, 16 May 2024 07:53:45 +0000
why should sierrachart version advaced 5 work with denali feed?
View Count: 425
[2020-08-10 08:28:00] |
User872218 - Posts: 1 |
I would like to order version 5. so far I have ordered version 3 Why should I add the Denali feed? I have subscribed to CQG via Ironbeam - isn't that enough? |
[2020-08-10 09:09:16] |
Yes it is enough just to use CQG. Also the Denali Exchange Data Feed works with all Sierra Chart service packages.
