Date/Time: Thu, 16 May 2024 15:05:50 +0000
ASCIL: User Input Changes
View Count: 571
[2020-08-09 08:11:47] |
BlakJak - Posts: 108 |
I am setting variables in my code for the study inputs to make it more readable than using the sc.Input[xxx].Get* functions everywhere. However, I do not want to set those variables during every call to the Study. I only want to set them if there is a change. Is there a code or flag that identifies when a user has changed an input, or at least a flag that the user has hit "Apply" in the Study Inputs window (even if changes didn't occur). |
[2020-08-09 09:05:19] |
Yes you will want to use this: ACSIL Interface Members - Variables and Arrays: sc.IsFullRecalculation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
