Date/Time: Tue, 10 Nov 2026 06:30:55 +0000
[Programming Help] - ACSIL sc.Input[].SetTimeAsSCDateTime()
View Count: 1709
[2020-08-06 08:26:56]
CMG - Posts: 179
1. Should this function return a Timevalue or a SCDateTime?
sc.Input[1].SetTimeAsSCDateTime(0);
If 00:01 (12:01 am)is entered in the input of the study, the function is returning 60 which is the correct timevalue. Shouldn't it return something like 0.0006944444444444446?
2. Coulnt find how to convert a Timevalue to SCDateTime
[2020-08-06 09:57:50]
User907968 - Posts: 885
You can use these functions to get the time data stored in your input:
ACSIL Interface Members - sc.Input Array: sc.Input[].GetTime()
ACSIL Interface Members - sc.Input Array: sc.Input[].GetDateTime()
You can read about TimeValue here:
Working with the SCDateTime Variables and Values: Time Values
You could, for example, set TimeValue of SCDateTime variable using this function:
Working with the SCDateTime Variables and Values: SetTime()
[2020-08-11 06:59:35]
CMG - Posts: 179
SC Support...
Refering to the original post: is this function working as described in the documentation? Is the return value correct (original post)?
[2020-08-11 09:20:36]
Not SC Support, but...
The return type for sc.Input[].SetTimeAsSCDateTime() is SCInputRef, not TimeValue or SCDateTime. (ACSIL Interface Members - sc.Input Array: sc.Input[].SetTimeAsSCDateTime())
Which actual function is returning 60?
I have studies using the sc.Input[].SetTimeAsSCDateTime() function, these were compiled using v2107 headers and they work as expected.
When input is 00:01:00 -
sc.Input[].GetTime() returns 60 (int TimeValue)
sc.Input[].GetDateTime() returns 0.000694 (SCDateTime)
[2020-08-11 19:15:48]
Also refer to this page:
[2020-08-11 21:16:29]
CMG - Posts: 179
907968 Thanks a lot for your answers,
Solved. I was using sc.Input[].GetTime() to get the input value from sc.Input[].SetTimeAsSCDateTime(). Now using sc.Input[].GetDateTime()
I thought sc.Input[].GetDateTime() was for sc.Input[].SetDateTime() only.
Thanks again
