Date/Time: Thu, 16 May 2024 05:35:51 +0000
I am very confused about what all I need.
View Count: 597
[2020-08-04 18:44:06] |
User911045 - Posts: 3 |
I had been looking around for a broker and found that AMP/Sierra was a common recommendation. So I have set up an AMP account. Now as far as what all I need with Sierra and AMP integration, I am very confused. I know that Sierra does not support Rithmic. I have seen that Sierra does not recommend CQG. However, I thought the data feed was coming from AMP, and they would be using CQG? I also saw that Sierra had their own feeds, but now recommends Denali. Is that correct? What do I need for Sierra for it to work with AMP? I am not even ask the question I am so confused about it. Can someone help clear things up for me? Thank you. |
[2020-08-04 18:48:26] |
What exchanges do you want to trade on?
[2020-08-04 19:00:20] |
I am only wanting to trade CME at the time, NQ and ES specifically.
[2020-08-04 20:18:06] |
SC Support - Posts: 1801 |
Hi User911045, we can give you a call to help if you wish.
[2020-08-05 03:20:19] |
Yes please, that would be very helpful.
[2020-08-10 14:19:24] |
Hi User911045, we have dropped you an email, lets find a time to speak. Thank you
