Date/Time: Sun, 19 May 2024 15:10:10 +0000
Using CTRL+A shortcut in the input cells
View Count: 516
[2020-08-03 20:49:45] |
Botan626 - Posts: 294 |
Hello, Could you make it possible of using CTRL+A shortcut in the input cells, like 'From' and 'To' cells in the Use Date Range settings in the Chart Settings? CTRL+Z, CTRL+X, CTRL+C, CTRL+V already work, but CTRL+A doesn't. Date Time Of Last Edit: 2020-08-04 16:07:37
[2020-08-06 16:15:51] |
Will be useful if you make it happen, SC team.
[2020-12-28 18:53:55] |
bump
[2020-12-28 20:59:14] |
Sierra Chart does not have control over this. It is controlled by the operating system.
