Date/Time: Sat, 04 May 2024 02:45:56 +0000
Simple Alert not loading to Alert Manager Log
View Count: 494
[2020-08-01 21:54:07] |
User910795 - Posts: 35 |
I am seeking to perform the most basic task of setting a simple alert on a custom study. The first time I loaded the alert(s) it loaded to the Alert Manager Log section just as it was supposed to. However, I needed to delete it from the log because it was not exactly what I wanted. I have gone back to the Alert tab on the study and entered what I want (SG30=TRUE) and hit apply, but it will not post to the Alert Manager Log. I have closed out and reloaded and done all I know to make it work but I cannot get a simple alert to "apply". Any ideas?
[2020-08-02 02:12:35] |
This would mean that particular Formula expression is not true. To help understand what is happening you need to enable this Alert Setting: Study/Chart Alerts And Scanning: Log Evaluated Formula at Each Evaluation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
