Date/Time: Mon, 06 May 2024 04:55:05 +0000
chart values and cross hairs
View Count: 1088
[2014-01-31 09:25:10] |
User40117 - Posts: 56 |
hi, you can examen the chart values in the small window with the crosshairs dynamically, but how to examen the custom or standard indicator values ? is this possible to get them in the window also ? ty |
[2014-01-31 09:31:04] |
Yes. This is documented thoroughly here: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ViewingToolandChartData You will want to use either the Window >>Tool Values Window or the Chart Values Window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-31 09:38:16] |
ty !
[2014-05-12 14:08:17] |
User88713 - Posts: 1 |
i've lost the crosshair synching across all charts on the page. how to get back |
[2014-05-12 15:58:24] |
You need to enable Tools >> Global Cursor On. This is documented here: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ChartValues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-12 15:58:39
