Date/Time: Sun, 19 May 2024 12:36:18 +0000
[User Discussion] - market/volume profile chart with candle sticks
View Count: 1981
[2020-07-31 08:26:59] |
User150508 - Posts: 2 |
How do I add candlestick bars to a TPO and volume by price chart?
[2020-07-31 18:56:08] |
You cannot have candlesticks on a TPO chart. Refer to the information here: Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-02 13:33:39] |
To create my trading levels I like to use volume profile(s) (that have the ability to merge) Low Volume Nodes combined with price action on one chart to create my trading levels. I would like to suggest a feature where you have the option to overlay price bars (candlesticks) on volume profile and market profile charts that have the ability to merge. This way you can see TPO, Volume at Price (mergable), and price action on one chart. I do know that other trading platforms albeit much more expensive ones that have this feature such as https://www.linnsoft.com/ which is commonly used and is one the core features of the platform. Thank you for your consideration. Kind regards, Steve |
